Hello! I have been trying to find a glue that would bond to gortex or
to a teflon based cord. Help! Nothing seems to work. Any ideas??
dd
dd
dd: Try www.thistothat.com. Their gluing form is limited to general
categories of things found around the house but you can probably find
what you need through this site. They also have a Links page and a
Glue of the Month page.
Christine in Littleton, Massachusetts, who wants you to know that
lung cancer kills more than breast, prostate, and colon cancers
combined.
For a pretty complete of what to use to glue 2 things together go to
Ivy - Oakland.
I’ve heard of something called “Gorilla Glue”. It available at
Loews Home improvement centers. There might also be a web cite for
this product. Good Luck!
I used to work for W. L. Gore. As you know PTFE (Teflon) is a non
stick substance.
When I worked in the wire wrap department, if you did multi
insulations with wire and the first wrap was PTFE, used to have to
treat the wrap with a pretty harsh chemical for the second wrap to
stay on (proprietary).
In the early days when you would sew Gortex together, they had a
substance that had to be applied to the holes the needles went
through, it was called seam sealer. I don’t know if they still sell
it, or if it was an adhesive.
Now, I think when they bond two surfaces together they do it with a
special adhesive (proprietary) and use heat.
This of course only applies if it is a two layer application, the
fabric and the PTFE. Otherwise if it’s fabric to fabric, I have no
clue.
They are friendly folks there, just call them. It’s been over 12
years since I worked there, but I believe the “Gore Tex” plant is in
Elkton MD.
The web site is “www.wlgore.com”
Carol
