Well, the inlay shop I ran in Albuquerque years ago had 1-36" saw,
1-24" saw, 4-10" saws, 6 - 6" saws, two Highland Park vertical
sanders, and about 12 10" grinding wheels scattered around. That’s
probably a biiiiiiiiit much for a novice… As with all things Orchid,
you will get varying advice. My advise would be to get anything on
this page, or similar:
http://www.kingsleynorth.com/skshop/search_results2.php?catID=126
I looked again at the cabmate, and I wouldn’t like it because it’s
much more difficult to cut cabs on the flat side of a wheel than what
more resembles offhand grinding. That’s partly because of the motion
of the wheel - a suface that is coming towards you, instead of
spinning past you sideways. It’s also pretty flimsy. Diamond wheels
are superior in many ways, but they are expensive and certainly not
necessary - learn how to use a wheel dresser and sharpener, and
you’ll be fine. My brother has been doing fine inlay for 25 years,
and he prefers silicon carbide. If you get a good combo unit -
Lortone is not perfect, but they’ve been in business since the
stoneage (pun intended) - it’s economical, it’s “plug and play”,
you’ll get everything you need, all in one box, including the saw -
a 6" saw will do you fine for quite some time, if not forever. Rio
Grande has some nice diamond combos for twice the price, if you have
it to spend, but I’m telling you, if you’ve never cut before, you
don’t need it. You can always change the wheels later, too. The only
real issue with combo units is the bearings - a 2 foot long shaft
with stress in various places on an aluminum base, and if you push
them hard over some years they’ll go out. Individual arbors and free
standing saws are mostly pro stuff- and a combo unit takes up about
the space of a microwave oven… Plus a hotplate, dopwax, cut-up
dowels for dopsticks - wooden matches for little stuff, cerium oxid,
tin oxide, LindeA, some abrasive belts - 220, 400, 600, you’re in
business. If you go diamond, you’ll need to learn the micron thing,
and charging disks - well, if you DO want to just dive into that,
good for you. I’m saying, though, for $350 or $500 you can be
cutting jade, and if you decide it’s not for you, you can sell it in
a week.
