Gesswein Colorit Seminars
Hi all, Gesswein is sponsoring a series of seminars over the next two
weeks. These seminars will introduce you to ColorIt. ColorIt is not
an enamel. It’s not an epoxy or resin. It is a ceramic-reinforced
composite material. It’s actually the same material (somewhat changed
of course) that the dentist uses on teeth to fill in, for example, the
gap produced by receding gums. This material is really hard (7-8
Moh’s). ColorIt is a liquid that comes in many different colors, which
can also be mixed to produce any shade (in transparent or opaque). The
colors can be soft and muted or bold & brilliant, even neon shades are
possible. Best of all ColorIt can be sanded, sand-blasted, filed,
buffed to high shine, inlaid, wire brushed. And it won’t crack or fall
out. It will withstand scratching much better than the gold or silver
you apply it to. It’s pretty cool stuff.
LA area May 16th 9am-3pm Days Inn Glendale 450 W. Pioneer Dr.
Albuquerque, NM Thursday May 17th 12pm-4pm Hampton Inn Airport 2231 Yale
Blvd. SE
Bring some pieces if you’d like and try it out. If you have any
questions or want to attend, email me. Regards, Ted Koch
@Ted_Koch
