Gas pressures?
I am returning to the bench after several years away. I have an
oxy-propane midget torch and cannot find in my notes what pressures
to use with the gases. I have 2-stage regulators and vaguely
remember something in the 30psi range, but am not sure and don’t want
to fool around. I would welcome suggestions for either or both
gases. I fabricate silver & gold jewelry and small scale metal
objects, and do torch enameling. Thanks for your help.
Linda,
If you keep your gas pressures to between 2-5 psi, you will find it
much easier to work. Melting happens a little slower, and there’s far
less firescale. 30psi is better for melting.
Doug
Douglas Zaruba
35 N. Market St.
Frederick, MD 21701
301 695-1107
@Douglas_Zaruba
