Another way to apply Fray Check: purchase a syringe with a
medium/large size needle, available at most farm/ranch supply
stores(or your drugstore). File the needle end round, to prevent
accidental injection, fill with Fray Check. Replace the needle
protective cap between uses for storage.
This method allows precise application of one drop or can "run a bead"
to cover a larger area when necessary. Also applies other glues
without having a larger area to clean up.
If using epoxy or adhesives which “set up”, just dispose of syringe.
Only takes a few seconds to blunt the needle & ease of use makes it
inexpensive! much less frustration!
-Marcia Ingham
