Our basement, including my workshop, flooded during a huge rain
storm last night. The foot control to my Foredom was immersed in 2 to
3 inches of water, best guess. I didn’t find that we’d been flooded
until this morning, and the water had already receded. It was plugged
in at the time of immersion. I haven’t tried to use it–I’m afraid to
risk it.
Is there anything I can do to help the foot control recover from the
unexpected bath?
–Kathy Johnson
Feathered Gems Pet Motif Jewelry
http://www.featheredgems.com
from the unexpected bath?
Just let it dry out. If you want, take the thing apart far enough
to reach the innards, and spray with WD-40. that stuff displaces
water on a surface, and can prevent rusting.
Leave it unplugged till it’s dry.
Peter
Hi Kathy,
I haven't tried to use it--I'm afraid to risk it. Is there
unexpected bath?
It probably depends on the type of foot control. There are several
types in the market place. The 2 basic types are a resistance unit &
the other is an electronic unit (used on the type ‘R’ & ‘TX’
Foredoms).
If it was a resistance unit, just setting the unit out where it can
get warmed a little & dry out will probably be all that’s needed. If
it’s the electronic type, putting it where it can get warm & dry out
may also work. However, depending on the internal circuitry, (if
there is a printed circuit board that’s gotten enough dirt on it to
short out some component contacts you may have a problem.
The best thing to do with an electronic unit would be to see if it
can be taken apart & examined for contamination. If there is some
contamination visible, clean it off with an old toothbrush or
similar. Let the unit dry completely before reassembling it.
Dave
Hi Kathy,
I would open it up and let it dry out. Try setting it on a bench
top with a light about 3-4" away for gentle heat to help dry it.
Mark
My foot control was in a minor flood as well and I just let it dry
out and then tried it. It’s still working 14 years later!
