Hello all,
Can anyone recommend a good flame resistant material (or good
materials) to put on the tabletop of and floor around my soldering
station?
Thanks!
Amy
Note From Ganoksin Staff:
Looking for a soldering station for your jewelry projects? We recommend:
Amy,
I still strongly support Homosote board and I also use fire bricks.
Jennifer Friedman
Ventura, CA
enamellist, jewelry artisan, ceremonial silver hollow ware
Yes Amy I can. Visit Cutter Northern Refractories in Woburn, MA They
have a website.
See my post:
on heat resistant pads.
http://www.cutternorthern.com
I have these on both of my soldering stations and and individual
pads under my crock pot. They will special cut for any size.
Nice people to work with.
-k
Karen Christians
M E T A L W E R X
50 Guinan St.
Waltham, MA 02451
Ph. 781/891-3854 Fax 3857
http://www.metalwerx.com/
Jewelry/Metalarts School & Cooperative Studio
station?
Cement board-- used for under tile floors.
–Noel
fire brick, Solderite soldering pads, kiln shelves…
Elaine Luther
http://www.CreativeTextureTools.com ™
Hard to Find Tools for Metal Clay
Ceramic tile… Fireproof, EASY to clean up spills, lasts 3 or 4
lifetimes? We use it around the kilns and casting bench too.
Brian P. Marshall
Stockton Jewelry Arts School
Stockton, CA USA
209-477-0550
instructor@jewelryartschool.com
station?
Amy, my hot work surfaces are covered with many different things.
For direct flame resistance I use combinations of the following
1/8 inch plate steel
concrete “backer board” sold for waterproof shower backing
tile backer board, a thinner smoother version of above
thin, 1.25 inch thick, firebricks, called half bricks by my
supplier
a big triangle of scrap granite from a countertop producer
If these surfaces are too abrasive/rough, you could use ceramic
kitchen tile, although the grout was a problem for me. I have heard of
using a metal surface covered with plastic laminate (trade names such
as Wilsonart, Formica). The metal substrate suposedly draws heat
away, but I expect it would still discolor or char over time. I do
know that a few years ago, you could buy metal surfaced plastic
laminate, which might be a good top surface for a metal sheet, or a
plywood floor cover.
Hello Amy,
station?
Since I’ve always made it a point to have a dedicated soldering
bench, I use 2 of the large (12" x 12") solderite pads as a base,
then set up my reflective pads or charcoal blocks on top of these.
When we teach classes away from Rio we use 8’ x 8’ masonite boards
over the original flooring of the room. This is great if you don’t
want to install a new floor and they can easily be cut to fit. We
use a heavy duty Duct tape on the seams, not pretty but effective.
Sincerely,
Thackeray Taylor
Rio Grande Technical Support.
