I am just starting out in the soldering process. I took a short
class, where I learned to solder with “easy” solder and made a
sterling silver linked bracelet. Of course, all went well during the
class- no problems with torch or solder. However, I have recently
purchased an Acetylene/Air Smith torch with a size 00 tip. I set up
my shop, and anxiously got to work making another bracelet. I have
encountered nothing but problems with the home shop. Clearly, I do
not know the temperature of my torch and have alternately
singed/burnt/overly oxidized scraps of sterling silver. For some
reason, the smaller gauge wire is easier for me to solder than 14g
sterling silver. Specifically, the process I was taught is: flux my
joint, let it dry. Heat the entire piece, heat a small snip of solder
until it “balls up” grab it with my titanium tip…heat the joint I
am soldering, then apply the ball of solder and VOILA! Currently,
when I heat my solder it lays flat and does not “ball up”… then if
I apply the blue part of my flame to it, it balls up rather
quickly… However, when put the ball of solder on my joint, it sits
there and does not flow. (Meanwhile the entire piece becomes
oxidize/singed). I have a feeling that the entire piece is not
heating (because I don’t see it glowing red), but how could it not
be heating when there is a torch waved over it??) I believe my
problems are related to not knowing the temperature of the flame- as
then the piece or the solder is over/under heated. Any suggestions/
knowledge of the Acetylene/Air torch would be appreciated! (I did
read the “5 problems encountered in soldering” article posted,
revisited the process… and still did not have any luck)
Brooke
