I am using horse hair in a project for a customer. I have secured the
finely braided hair in some silver crimp type end-caps. I would like
to add some bees wax or glue for extra protection but I am wondering
if epoxy or even super glue will break down the hair over time and
cause it to fall apart. Any help would be much appreciated!
I am using horse hair in a project for a customer. I have secured the finely braided hair in some silver crimp type end-caps. I would like to add some bees wax or glue for extra protection but I am wondering if epoxy or even super glue will break down the hair over time and cause it to fall apart.
I would suggest hide glue, which you can get from a decent wood
workers supply. It’s one of the types of glue that is not likely to
breakd down the hair before natural wear and tear will.
Horesehair used in violin bows is not glued but wedged into place
even though some tension is involved - maybe the early makers found
that glues didn’t work? However, Cyanoacrylates ( superglues ) are
used medically and so should be compatible with biological
materials. I would probably look at the flexible cyanoacrylate glues
such as this
[ebay link removed. sorry no ebay links on orchid]
Ian
Go ahead and use glue on your horsehair - glue has been used with
hair for many long years. I recommend a jeweler’s glue (2-stage
epoxy or E6000), not a water soluble glue or super-glue.
Sandra Graves,
Isis Rising
