I am a self taught metal artist and have decided to go back to
school, the torch set up at school is natural gas and oxy, I use a
smith little torch propane oxy for 15 years, I am also dyslexic.
My problem is I am afraid of the torch, any ideas on how to get over
the fear of being around beginning students lighting torches. I know
I don’t crank down the oxygen as much as other jewelers, but I taught
myself how to solder. I was told the teacher likes to scare students
with the torch, help, any good tutorial on how to get over the fear
that someone will do something stupid,
Think, relax, and open your mind. Fear is inhibiting while repect is
empowering. Repect your torch, and when possible encourage others to
do the same. Accidents can happen, as can bone heads (soldering two
domes without an air vent driled into one of them, heat, gas expand
rapidly, metal foes flying). Remember the basics:
You don’t want to light oxygen, therefore fuel out, then oxygen.
Oxy off then fuel.
For an enclosed vessel, if there’s air in there then it will want
to come out as air expands when heated, which of course soldering
will do.
Relaxation techniques will help with the trepidation, as does
acceptence of what can happen. We can easily be afflicted by such
throughout our daily lives, but developing agorophabia out of fear
doesn’t help you. Moving metal, heating to allow the crystalene
structures to realign, helping connect the bland to make to
extrodinary. In short embrace the joys of what a torch offers the
metal artists and all the wonderful things that are happening on a
level we can’t see and you’ll more likely to come to love working
with the torch.
With regards to others, it won’t take long for you to learn who you
don’t trust to work around, also if horseplay start to occure, then
simply walk away and come back to your work when it’s safe.
Good luck in your metamorphasis from torch-fearer to torch-embracer.
Kindest,
K. David Woolley
Fredericton, NB
Diversiform Metal Art & Jewellery
I was told the teacher likes to scare students with the torch, help
Vicki, if this is true you should really do yourself a favor and
find another teacher and another school. Any knucklehead who would do
such a thing is not a good teacher. If you’re already a metal artist,
there are plenty of books and instructional videos that can be of
more use than such a “teacher.” Check ganoksin.com’s The Jeweler’s
Selected Bibliography to find plenty to choose from.
any good tutorial on how to get over the fear that someone will do
something stupid, I know this isn’t what you’re looking for, but
getting completely over that particular fear is not necessarily the
best solution. If you can replace the fear that someone will do
something stupid with an awareness that someone might do
something stupid, you’ll be creating a safer environment for yourself
(in any situation) through increased alertness.
Of course, nothing can protect one from idiotic horseplay, such as
scaring the students with dangerous equipment. If that’s the case,
continue looking for a different instructor or avenue of instruction.
Books and instructional videos about goldsmithing aren’t exactly
cheap, but they don’t sneak up behind you, fill an upside-down paper
cup with gas and ignite it behind your back POW!
When I was at college I had the same issue with fear of the
torch…we had a oxy and natural gas system aswell and had two types
of torches…one was a smaller melting torch and the other was a huge
casting torch…I am 4ft 10 and this torch was as big and as heavy as
i was…and offcourse the loud bang that occurs when u are turning
the flame off and foget to turn the oxygen off first doesnt
help…What i suggest ou do is to to remember on which side the taps
are for the gas and oxygen and if u forget the colour of the piping
should indicate, usually its red for the gas and blue for the
oxygen…that how i always remembered never to turn the gas off
first…I held the torch in my hands and made friends with it
almost…study it and get comfy with it in your hands…the story of
the teacher that will use shock therapy on you would basically mean
he/she will make it “POP” by turning the gas off first…thats
all…it will make u jump the first few times…but always remember
to keep the torch nozzel up towards the extractor and away from
you…visualise if u think you going to forget, remember that when
turning the torch on you have to light with gas so the first flame u
see if an orange fire flame…and thats the last type of flame you
shuld see when turning off the torch…
I hope i have explained myself well enough foryou to understand…i
can get so lost in thought that i dont make much sense…hope this
helps…its gets better the more u use it, so dont avoid it likei
used to do…
Ask one of the other students for help. More often than not the
students are better teachers than the “teacher”. They are going
through a similar experience and might understand your concerns
better.
over the fear of being around beginning students lighting torches.
I’m guessing that this is something that is not a trivial matter for
you. I can’t answer your specific question, as I don’t have the same
fear. However, speaking as someone who has to find a way to deal
with various fears, i thought I might speak up.
I believe that where there is one fear, there is usually a few more.
I also believe the old adage “face your fears head-on” is dead wrong.
I have faced my fears before and was only left terrified and a bit
nauseous.
Try to find what would bring you comfort. In the class I was in, the
torch was lit inside a big fire-proof box with only the front of the
box open. This seems like it might help. You could let your
instructor know of your nervousness before the class. That way
he/she might be sensitive enough to not scare the ** out of you.
I have a fear of crowds. It’s a pretty big one for me. I never go to
wholesale shows. However, since I would like to exhibit at larger
retail shows, I have to find a way to deal with it. To me, the
construction of my jewelry display case is very important. It has to
be made in such a way that it will provide a comfortable barrier
between me and the public (with no room for anyone to come behind
the jewelry case itself as this is my “space”). To someone without
such fears, this behavior sounds bizarre, but such is life. I do what
I do.
Good Luck, and know that your mind is making your fear bigger and
bigger. If you find a way to go to the class and go through having
the torch lit by a student, you’ll probably look back and say, “that
wasn’t bad at all”
Now that’s a bizarre tale!!! A teacher who likes to “Scare students
with the torch!?!?!” What kind of idiot could he be? It’s not that I
disbelieve you, it’s just bizarre that anyone could be that stupid. As
for your fear of the torch, I would suggest that familiarity and
practice should solve that, and using common sense precautions -
always point it away from you, etc. As far as the teacher - IF it’s
actually true (it could be a school rumor, like Mrs. Hatchett keeps
snakes in her basement), then I would suggest that you be the one to
stop it. If he should do such things, let him know you don’t think
it’s funny. If that doesn’t work, tell his boss you don’t think it’s
funny. I don’t think it’s funny…
Vicki - I recently finished 3 years of university level jewelry
design after 35 years owning my own business (not jewelry related).
When I began school I too was afraid of the torch but found that
using the natural gas/oxy was safer in the school setting than the
other setups I have used at the craft guild, etc.
My best investment has been the electronic torch lighter. I found
the frustration and lack of reliability of the spark flint type of
lighter caused me more anxiety than anything else. I highly
recommend the Torch Mate or any of the numerous type of electronic
lighters on the market through Roseco, Rio Grande or other supply
houses. Keep trying…practice makes perfect!
Lighting a torch is a serious matter. Any teacher who ‘likes to
scare students with the torch’ should be sacked, tarred and feathered
at the same time! I hope the allegations are not true.
I find at least one student out of 10 is afraid of lighting a torch.
My way of handling it (others probably have their way) and de-mystify
the process, is to demonstrate everything about the torch system
first. From the tank to the tip…explain it all, what it does, how
it does it and why. Then explain the electronic lighter (i.e., its a
mini-taser essentially). Then I light the torch and explain different
types of flames, how to adjust to get the flame you want, and what
each is used for. At that point, each student must light the torch
and adjust it. No one is exempt. If someone is hesitant, I hold their
hand while lighting, several times if necessary. Then they do it
solo.
That usually resolves their immediate fears, however, some continue
to flinch for some time until they become completely at ease.
The moral of this little story is, practice in a controlled
environment is the best teacher.
elegance IS fine jewelry!
