To smooth the channel walls on small channel settings, a roller can
be made from an old millgrain wheel. Carefully grind away the metal
ridges that form the beads, leaving a smooth channel around the
outside of the wheel. Then polish to a high shine. Place this
modified wheel in its handle and roll it over the top of the channel
wall in the same manner you would use to millgrain an edge. The
result is a smooth edge of metal burnished tight against the stones.
This modified millgrain wheel works equally well on bezel set
stones.
Brad Simon CMBJ
