I sometimes use broken saw blades when setting up a piece for soldering.
When you need a part raised just a teeny bit higher, a sawblade or
sawblades spaced a little bit apart can do the trick.
They can also be used as tiny files in those tight spaces where nothing
else will fit.
Looking forward to hearing more uses for those pesky broken blades.
