Hi there – I’m curious about fabricating a piece in palladium. Do I
need any special tools really? I will get some palladium ez & med
solder & metal from H&S. I’m assuming that the soldering is about
the same routine as gold or silver, but higher temp… Should I wear
dark goggles for soldering? Any special soldering tips I should be
aware of? I have a standard propane/oxy set-up with a meco midget
torch and I’m going to first make a fairly simple bezel with jumpring
dangle piece.
Thanks!
cheyenne
