I am looking for a portable torch to do some light soldering at
shows. The ST900D looks like it might do the job. Does anyone have
any feedback good or bad? Thanks.
Tom Wohlfeld
Note From Ganoksin Staff:
Looking for a jeweler’s torch for your jewelry projects? We recommend:
I teach silversmith classes as a volunteer at our senior center. We
use Smith acetelyne / air. When students want a small portable unit I
recommend the ST900 D with MAPP gas. It is almost as hot as the Smith
units and is locally available.It is not suitable for heavy melting
but will solder silver or gold.
I use the Proxxon mini torch ($56 from Rio Grande) or Blazer for all
my bench work. There are no hoses & they use readily available
Butane. They 're very easy to handle, have a flame to 2500 degrees &
if I’m working on avery large piece, I use two.
There’s an article
about all the different torches that you might find useful.
I live in a tiny apartment and didn’t want to risk a stumble over a
“big girl” torch. The ST900D is perfect for the kind of soldering
jobs I do. I use the Coleman 1 lb tank of propane that’s available
from a camping store. It’s lower to the ground and one can buy a
plastic “foot”/stand that makes it more stable. No need to tie it to
a table leg. Very easy to maneuver the flexible gas line. Highly
recommended for shows, demos and to folks who want to graduate from a
hand held butane mini torch. Larger jobs can be assisted by placing
the item to be soldered (or otherwise heated) on an Ultra Light
kiln).
Lora
