Seems that those who do, know, those who don't, don't know.
Centrifugal casting by hand or machine is casting, not
fabricating.
Thanks for the insult
My concern was the wording of sections 23.3 being too open. However
James provided a better explanation, and filled in the missing link.
I was just missing that one point.
I’m in total agreement thanks to him.
Charles, if you made knives, forging knife blades is handmade. If
you knew someone buying a stamped out knife blade and putting
handles on it and calling it handmade, what would you think?
Well, funny you should mention that. I forge knives, swords, and
other blades, I get the bevels close, then I tidy up the bevels with
a motorised belt, sometimes I use a sen or a B.A. file.
The finishing I do on my blades, I just use an up-scaled polishing
lathe. I pretty much finish the job like any jeweller would… with
a machine.
Other people buy stamped out knife “blanks”. The knife blank is
shaped with a bench grinder or belt, by hand. Some makers make their
own blanks, and grind to shape.
If one of these makers put “hand made” on their blade, I couldn’t
dispute it, if they were subject to section 23.3.
I’ll even go a step further. Some makers don’t even make their own
blades, they buy a pre-made blade, they just make the grip.
Two groups. Those that understand and try to explain to those that
don't, and those that don't understand and seem to act as a
support group to help each other remain ignorant.
If the group that “understands”, fails in the explanation, they
perpetuate the ignorance.
No one, bar James Binnon, said anything but “casting isn’t hand
fabrication” (or “/Centrifugal casting by hand or machine is
casting, not fabricating/”), without giving any further explanation.
Because of James’ concise explanation, not only can I support his
view, but I can pass on correct validated I can give a
reason, not a statement.
He also explained without the insult.
Regards Charles A.
