Would the heating up time be shortened if I use an electric
pickler?
Yes. But the Ferris picklers are a lot more expensive than a crock
pot. And if you happen to drop a hot piece of metal of sufficient
size into that pickler, sometimes you can crack that pyrex beaker
they’re built out of. Unrepairable. You’ll never do that with the
ceramic containers of the crock pots.
Two options. Go to the slightly larger crock pots that have more
than on off capability. If I read between your lines, you’re using
the little one that either plugs in to turn it on, or unplugs to turn
it off, right? That’s intended as a potpouri pot, not for active
cooking. So it’s low power. Not really meant for boiling your meal.
That’s why it’s slow. I use a one quart size from Target that cost me
somewhere around 12 dollars. the removable ceramic insert is easy to
clean, or carry to the sink for cleaning, etc, if needed. Has a
cover, and importantly, a three position switch. On “low”, it simmers
at an appropriate pickling temp. But on “high”, it heats the pickle
to almost boiling within perhaps 20 minutes or less, and warm enough
to be useful within half that time. The Ferris picklers are not
faster than that.
Alternatively, if your little pot has a removable ceramic insert,
you could always pop it into the microwave for a minute or two to
pre-warm it. if you only warm it up, not boil it, you won’t get
pickle fumes into your microwave…
Ok, shop chemicals in the kitchen microwave may not be the best
practice in many cases, but pickle is pretty dilute, and unlikely to
make your microwave unsafe for food, especially if you cover the
container loosely, and only warm it up, not boil it. Run a paper
towel around the inside after heating just to be sure. I actually got
a cheap microwave (saw it on sale, again at Target, for 40 bucks)
that I keep in my shop for quick heating of anything. That includes
for warming up things like thermoplasic compounds like jet sett
(immersed in water, usually), to heating up the electrocleaning
solution if I need to do some plating. I do refrain from heating some
things like cyanide based plating solutions in there, simply because
of potentially risky situations with subsequent incompatible things
later on. For those, there’s still a hot plate. But for most simple
quick heating like this, it’s worked well for my shop.
And one other odd suggestion that works. Have you ever seen these
little electric hot pads intended for keeping a cup of coffee
drinkably warm? They work just as well with, say, a 400 ml pyrex
beaker of pickle. Or for that matter, a coffee cup, if made of an
appropriate acid proof ceramic or glass. Again, you can preheat in
the microwave. Or just let the pad do it. Slower than the microwave,
but it’s not three hours by any means.
Peter Rowe
