Ted, I have been thinking about that, I have the Durston 130 mill,
but love to motorise it, any suggestions what kind of motor you
need and how to do it?
Hi Peter,
The numbering of Durston mills may have changed since i bought mine
over 30 yrs ago.
Mine has 5in wide rolls, half is flat and half is square grooves,
and it has shaft extensions for additional section wheels.
The rolls run in plain aluminium bronze bearings To motorise mine, I
hunted down a cast iron electric grinder stand.
Onto the top of which I bolted the mill.
Then I removed the handle with its gear thats hollow, that turns on
a fixed shaft set in the mill body.
Had durston send me a spare gear with its parallel shaft onto which
I mounted a 9in dia aluminium 2 “A” section pulley.
Then I mounted half way down the grinder stand a flat steel plate
onto which I bolted 2 bearings that took a 1in shaft.
On to this I had a 2 section 3in pulley and inside this one another
12in pulley single “A” section. both grub screwed onto flats on the
shaft the shaft.
Then down near the stand base a 1hp 1440 rpm motor with a single 1in
dia pulley.
total reduction from the motor to the mill imput gave an rpm of 40.
The drive belts are pretty tight and any slip was on the motor
pulley.
Theres a particular rolling job I do occasionally that needs me to
use the handle. I have to roll some square section material for 1in
then reverse the handle direction to back it out, reduce the roll gap
and repeat progressively along the material.
To do this I slacken off the mill bolts, remove 2 opposite the 12in
pulley, tip the mill to lift off the 2 final belts then put on the
handle.
Belts are safer than gears. I can mill long lengths of material with
2 hands to guide the in and out.
I found in B’ham some 20 yrs ago another hand mill, some what
studier tho still 6in wide rolls.
This had a 24in cast iron wheel with a handle on it with similar
mill rpm reduction.
I motorised this mill for a big rolling job where I had to take a
36in long by 3in wide 70/30 brass strip, and reduce it so it became
48in long. ie from 036 to 029 in.
There I used a 3hp 1440rpm motor also with a 2in single “A” pulley.
This worked well with suitable imput guides.
Total no of brass strips to roll 210 for a 2500 off minting project.
Hope this helps.
Ted
