No one has mentioned, sometimes the string they are strung on is dyed, not the beads. If you test the beads on the string, you may see color if you immerse the beads in water or acetone. The dye on the string enhances the color of the beads, so they appear to be a darker color. The beads will be the same color as they were when you bought them, they were pale, they just looked better on the dyed thread. I think anyone who works with beads has seen this with rose quartz beads strung on red thread.
I mentioned this when I was describing the isopropyl bead soak I’ve
used…
As Richard mentioned, the temp strand is often dyed to make the
whole thing look better… So when you soak beads in whatever, you
take the beads off the strand…
The other issue is, is that if the strand is heavily dyed, you
will have dye deposits in the holes of the beads from the
strand…and isopropyl will pull those out…
A lady beader friend clued me onto this…
BTW…for folks thinking maybe about the deleterious effects of
isopropyl (I use the 70% rubbing alcohol from the Walgreens’…it
works better than the 91% stuff does it seems) on stones…2 pints
for $1 when on sale…
If a water bearing stone, yeah, will suck out the water…as well
as many dyes…
I don’t know for sure, but an organic gem probably won’t like it
much either…
If your stones and beads or whatever are oiled…it will pull that
out, too… Be prepared…
The Ph seems pretty close to neutral…maybe a tad
acidic(?)…checked with PH paper back when I first started using the
stuff…because acidity bothers some stones and alkalinity bothers
others…and some are bothered by both…(like lapis, for
example)…
I suppose vodka (ethanol) would work for this, too…but for 70%,
you’d need 140 proof…
Better for making killer Screwdrivers and Bloody Marys…
Denatured alcohol from the local hardware store paint section would
be another source…but haven’t tried that stuff…
That’s also where you’ll find acetone for the cotton swab dye
check…
Nail polish remover comes with additives usually…in addition to
the acetone…
Gary W. Bourbonais
A.J.P. (GIA)
