Difference in types of gas tanks
What are the differences between the MC and B acetylene gas tanks
besides the size? Can an MC tank be used with a Prestolite torch?
Everything I’ve read recommends using a “B” tank, so I’m curious.
I called my insurer about setting up a work area in my garage. I was
pleasantly surprised that he didn’t freak out. I explained to him
that it would be at a hobby level for now but I might expand in the
future. I also dropped him off a lapidary journal and some other
so he could see how a torch would be used. I’ll follow
through later in the week and let you all know what he says in case
anyone else is interested.
Cheers,
Tracy
Tracy’s Treasures
Everything I've read recommends using a "B" tank, so I'm curious.
MC tanks have a smaller fitting than B tanks. They will also
obviously run out of fuel sooner. Adaptors are available to adapt
either up or down between them. I have never had any problems either
way. A B tank is probably just the old standard size for the
prestolite torch.
Dan Wellman
The B tank has a larger threaded connection than the MC. I have one
of each. The smaller MC is in a portable rack that came with my full
sized cutting/welding outfit, the B sits in a rack that’s much more
substantial. Eventually it will be mounted or set up with a wheeled
cart once I get my permanent work space set up. I have an adapter set
that lets me switch my torches between tanks (my Smith torch came
with B connection).
@Ron_Charlotte1 OR afn03234@afn.org
