Hello Carin,
Here are three ways I can think of that may help you.
- Foldforming Like pastry dough, metal too can be formed over a
form, in a hydraulic press. You will need to prep a die plate first.
The die plate can be made by cutting out discs from 3mm high (1/8")
acrylic sheet or you can get them here,
http://www.ganoksin.com/gnkurl/1hz
You then arrange these discs on a sheet of acrylic glued into place
using acrylic monomer. The dead soft raw material can then be forced
over this dimple covered sheet forming a sheet of road bumps. This
dimpled sheet is then be put into a disc cutter and the individual
bezels are struck and then cleaned up because they will have a flange
off of the bezel wall from the difference between the diameter of the
acrylic disk and the diameter of the cutter used.
As far as how far to place the acrylic dimples apart, this will
depend on the height of wall on the bezels and how much clearance your
disc cutter requires, this tolerance could be as small as 10mm between
dimples.
The largest benefit to this technique is that you are not limited to
using just round discs in one size. You can make bezels for any size
stone and essentially in any shape that you will ever need (odd shapes
will need to be sawn out). Something to think about.
Cost:
Not including the hydraulic press, You will need a disc cutter (in
this case a $25 Harbor Freight cutter will work). You will need 1/4"
acrylic sheet or discs and acrylic monomer, the total cost should less
than $50. You will also need a 1/4-1/2" urethane sheet ($40-50).
- Modified Disc Cutter
This idea requires you to use a disc cutter and disc punch that have
been machined for this purpose. You will need a disc cutter that grips
onto the metal (like the Swanstrom disc cutter) and you will have to
have the disc punches specially machined.
You can’t use the Harbor Freight disc cutter because this doesn’t g=
rip the metal so there will be a lot of warping, tearing, etc…, plus
the metal used on H.F tools isn’t the greatest… Example: Using a 14mm
punch, you will need to have the base (3mm from the base, the bezel
wall height) machined down to 12mm diameter. This will form the bezel
cup and shear it off creating a 12mm diameter cup that is 3mm high.
This technique will create a flange that will need to be sanded off
because of the difference between the 12mm “bezel die” and 14mm
shearing punch.
The benefit to using this technique is that your metal can vary up
to almost 1mm thick and still create a bezel.
Cost:
Not including the cost of the hydraulic press. You will need to
purchase a disc cutter ($270-$500), and you will need to have the
disc punches machined for making bezels which could cost anywhere
from $20-? depending on what tools you have on hand, where you live,
and who you know. If you have have this done for you count on it
costing at least $100. You will need a urethane sheet 1/4" thick so
that the cutter isn’t damaged during use ($40).
- Specially Made Die and Punch
The only way to get repeatable, perfectly struck bezels is to have a
bezel die and punch specially made. This route will start out at $500
and can easily run into the thousands for a single size die, which may
be an acceptable route depending on the amount you need. A die like
this can allow you to stamp upwards of 10,000 bezels (about 5cents
added to each bezel cost if the cost is only $500) before needing to
be replaced. A older dull die doesn’t need to be thrown away, it can
be re-sharpen= ed and if you have a slightly larger punch made for it
you can make larger bezels for the cost of the new punch. As far as
companies that can do this, good luck! So many either have closed and
the companies that are still open keep raising their prices!
The benefit to using this setup is that you will have perfect bezel
cups that you will not have to fuss with (except to lower the wall
height depending on the stone).
There are all sorts of issues that can encountered by using either
of these methods.
Foldforming
The raw stock will have to be dead soft and even then the cups
will bow slightly outwards using this technique.
The bezel cups will need to be filed to clean up the edges.
Even though you can use this method to strike bezels from
30gauge to 18gauge thick, with each increase in metal thickness you
will end with a more pronounced flaring of the bezel wall.
This will put a lot of extra stress on your disc cutter’s
cutting holes which may render it useless for punching regular discs.
You will not be able to strike bezels using a hammer, you will
need to use a hydraulic press. The bezel punch will need to be as
centered as possible when striking because any deflection will require
the punch to be re-machined.
The cost of this setup can be prohibitive
You will only be able to strike one size of bezel
You will need to use this tool in a hydraulic press, because
there is too much risk in damaging it using a hammer
Cost Effectiveness of the Techniques
#1 When you do the math using either method #1 or #2, you will
only be saving about 50 cents per bezel cup, plus you will still be
left with clean up which will cost more then 50 cents in labor.
#3 If you go with #3 you will be able to create 12mm bezels that
cost about 40 cents. 30 cents for the silver, 5 cents for the die
wear and tear. This is if you can get the die and punch made for
$500, but plan on it costing around $1,000.00 so you won’t be as
surprised when you hear the cost.
My goal isn’t to deter you, but you may want to stick with your
current supplier, this way you can always be ensured a consistent
supply of a usable product. If they ever supply you with unusable
product, you can always return it for exchange which is a nice fall
back. While $2.50 may sound like a lot for the bezel cups, on paper,
in reality the cost, time and, labor required to make the die and
punch as well as the time and labor required to actually strike the
individual bezel cups may not be cost effective.
Perhaps you can call your supplier and discuss quantity discounts,
they usually require you to buy a specified quantity before any
deeper discounts take effect, but if you buy a specified quantity
over a length of time, they should be wiling to work with you. You
can always threaten to take your bulk business to one of their
competitors.
Speaking of suppliers, if these cups are sterling silver (going from
your Etsy listings), where do you get sterling silver bezel cups for
$2.50? Rio’s quantity discount is like $3 each.
Sorry for the long post!
Take care, I hope I was some help
Kenneth, DynastyLab
http://benchofanapprentice.blogspot.com/
