Following a discussion on Facebook, what is the name for where the
pavillion facets meet on the bottom, the point where they meet.
Richard Hart G.G.
Denver, Co.
Richard Hart G.G.
Denver, Co.
Is that a trick question? Technically there should be a tiny facet,
which is called culet or culette. The facet is octagonal, so there
are 8 corners where pavilion facets meet. Each corner is a common
point to culet and 2 pavilion facets, which meets requirement for
definition of a vertex.
Leonid Surpin
Hi Richard,
That would be the “culet”.
I know I’m in Australia, when I pronounced “culet”… “culay”, and
my teacher pronounced it “cul-let”
Here’s a link anyway :-
Regards Charles A.
Following a discussion on Facebook, what is the name for where the pavillion facets meet on the bottom, the point where they meet.
Do you mean if there is not a culet?
Hello Richard,
This point is named “the cullet” If a diamond is cut correctly, this
point is exactly the center of the stone where all angles from the
paviljon finish in one symmetrical point. For chipping isue’s this
point is often minimal flattend and polished. The name cullus is
derived from the latin word “culus” which means “anus” pointing to
the very last part where everything comes together. No further
explanation needed I think -)
Have fun and enjoy
Pedro
what is the name for where the pavilion facets meet on the bottom, the point where they meet.
I was taught that it’s called the culet.
Lorraine
Richard,
I am thinking you mean where the two bottom halves" using diamond
cutting terms" meet??? Would be called facet junctions.
Roger D. Flanders
Ah, you’re the sly one, eh? The point ot which you refer, If having a
facet, no matter how slight, is the culet. If no facet then it is a
"closed culet"
Jerry in Kodiak
The point at the bottom of the pavilion is the culet. If there is a
flat facet at the bottom, as in many very old diamond designs, it is
the culet facet.
Jerry Bartlemay
Portland, OR
cullet is the term and is usually cut at a slight angle so you do not
have a true point. Why I don’t know but have a few guesses in mind.
John
(Jack) Sexton
not have a true point. Why I don’t know but have a few guesses in
mind.
John
(Jack) Sexton
