I have an interview this week with a jewelry manufacturing company
and it includes a half hour dexterity exam. Does anyone have any
tips to offer about this process? What should I expect? I’ve never
experienced anything like this and am a bit nervous.
I once worked with an agency that did dexterity testing as part of
the screening process. Basically, people had to stack washers on a
peg, put items in a slot, fold a piece of paper, etc. I wouldn’t
worry about it too much. The face to face interviews will have more
of an influence than a dexterity test will.
tips to offer about this process? What should I expect? I've never
Wow! I want to take one! It would be a hoot. I’d probably spend half
the test assuming the ‘jeweler’s position’. Hands and knees on the
floor, butt in the air - looking for for the stuff i keep dropping.
I’m looking forward to hearing from others who have taken dexterity
exams. I’d imagine they aren’t too bad. I think tests like those are
aimed at evaluating hand/eye coordination and finding out if there
are any major issues.
Don’t forget to breath- many of us tend to hold our breath when
we’re concentrating, and that starves the muscles of oxygen, causing
the neck and shoulder muscles to stiffen up. In my case, a few cycles
of holding my breath while working, util I gasp for air also makes me
a bit- ok, a bit stupid. So if you find yourself holding your breath
and getting stressed, sit up straight, take a deep breath in through
your nose, and out through you mouth, repeat a couple of times, and
you’ll get back to your task calmer and not so tensed up and
frantic.
Well, I went to the interview and they did actually have me work
with their tools and make things. All I had to do was show that I
could follow directions with pliers, wire and a hammer. I did well
and was offered the job! The only tip I have after experiencing this
is to not be nervous because shaky hands will just make you more
nervous. Deep Exhale…
Wow! I want to take one! It would be a hoot. I'd probably spend
half the test assuming the 'jeweler's position'. Hands and knees
on the floor, butt in the air - looking for for the stuff i keep
dropping.
LOL LOL! Somehow I think Kate’s ‘jeweler’s position’ might be a bit
more attractive than mine…
I think you’re right-- the key to hand-eye is first relaxation,
which is best done by seeing the project as fun. The next is to
crawl into the scale of the piece-- this jewelry scale is about as
small as hand-eye can do, so it takes a sort of ‘doll-house’
approach-- see that post and that ball of solder as a baseball-bat
and tennis-ball, and that molten flux like a gallon of honey, it
gets more realistic.
Finally, when all else fails, take the advice of the great
ceramicist Peter Volkos, and “Will it into place”!
I would think a dark commercial flat-ish carpet would be best. I
drop no. 15 seed beads all the time and I can find them better on the
darker carpet I have than the old light carpet I used to have.
