There’s that age old struggle between designer vs manufacturer, architect vs engineer, and jeweler vs caster. I’m a strong proponent of having the jewelry designer and caster collaborate on the design. If the designer is good, they’ll understand the limitations of casting and will work the design around that. But a lot of the time, it becomes the casters job to find ways to make the design work regardless.
And speaking on CAD designing, I’ve noticed when I’m working in CAD, that what you’re seeing on the computer screen looks like it should be adequate size in real life. It wasn’t until I would print things and see that “wow, this design or component in the design came out much smaller than I anticipated”. I began using the measuring tool much more to find the exact dimensions of what I’m designing. And if I’m questioning the size of a particular design element, I’ll pull out some calipers and see what the actual size would look like in real life. Even then, there are times when I print that I’ll need to go back into CAD and adjust or tweak things on the design to get the right proportions for casting.
A way to get past that is to use sticky wax pellets (I got mine from Rio Grande) and I have a small wax pot where I dip my wax sprue into it. Guaranteed adhesion. Just shape it with your hot knife to get rid of the sharp edges and you are good.
I’ve worked with that stuff before back when I worked in aircraft engine manufacturing. It definitely works, but I can’t stand the stuff…actually for exactly the reasons it’s so good. Sticks to everything, burns like a bugger when you get it on yourself, and is a devil to get out of clothing when you drip it on yourself. Smells good though!
But, my personal gripes about it aside, it’s definitely a good idea for sprue attachment to these printed models.
I read your comments about PowerResins Dark / Black expansion and investment cracking, and it sounds very relevant to a problem we are currently facing.
We are a jewelry manufacturer in Slovakia. For many years we used EnvisionTEC EC500 on Perfactory/Aureus printers for direct investment casting, with virtually 100% reliable production results.
Since EC500 is no longer available, we are testing PowerResins Dark / Zero Dark.
Our current setup is:
Resin: PowerResins Dark / Zero Dark
Investment: R&R Plasticast
Issue: clean burnout overall, but very fine investment details sometimes break during burnout
This did not happen with EC500 using our previous process
Our current burnout cycle is:
Ramp to 150°C in 1 hour
Hold 150°C for 3 hours
Ramp to 800°C in 3.2 hours
Hold 800°C for 4.3 hours
Cool to 630°C and hold until casting
I understand this is different from the official PowerResins cycle, especially the missing 550°C hold, and we plan to test their recommended schedule.
May I ask a few specific questions?
When you mentioned PowerResin Black expanding too much, did you mean PowerResins Dark / Zero Dark, or a different resin?
Which investment did you have the best results with for PowerResins Dark?
Did you ever test Dark with R&R Plasticast?
What burnout cycle worked best for you with Dark?
Did switching from Dark to PowerResins Wax reduce investment cracking or broken fine details?
For very fine pavé / prong / small stone setting details, would you recommend Dark, Wax, Burn, or another resin?
Do you use any UV post-curing with these resins, or only wash, dry, invest?
Any practical experience would be extremely helpful, especially from someone who has dealt with resin expansion and investment breakage.
