I'll ask my friends if their work is plated in anything. I thought
it was straight cast pewter, but could be wrong as I never thought
to ask. It doesn't appear to be plated. Would cast metals have a
different makeup or perhaps a different kind of finish that would
cause a reaction?
Pewter is not normally electroplated. It does, over time, get a
little darker in color, but it doesn’t tarnish the way silver does,
and is easy to clean, so normally, electroplating isn’t required. The
metals I was wondering about are so called “white metals” which
specifically are NOT pewter. Not at all. Rather than being mostly
tin, these are often zinc based alloys, or mixes of a bunch of
things, sometimes including cadmium and lead. These alloys are not
generally fabricated, but are often used in casting, especially by
mass market manufacturers, and These sorts of things are almost
always electroplated. This is often the mainstay sort of alloy used
in costume jewelry.
If you’re talking about quality artist made jewelry, in alloys of
pewter or similar to pewter, especially if fabricated instead of
cast, then most likely, actual pewter is about the only likely
option. If cast, rather than fabricated, there are a few other
options beyond just pewter, that might be used by small scale
craftspeople and artists, but even then, pewter is the most likely
choice for any sort of quality work.
One big difference between cast metal and fabricated metal (and this
can apply to any cast metal, not just pewters or the like. silver,
gold, platinum, or others also are included) is that castings have
porosity. Virtually always. it’s just in the nature of most metals to
behave this way. What varies is how much porosity, and how small the
pores are. In good castings, there won’t be a lot of porosity, and
the pores themselves will be too small to see without a good
microscope. In poor castings, the metal can approach almost sponge
like consistancy. I’ve seen casting where, if you clean the item in
an ultrasonic, steam it off, and towel dry it, and then heat it up
again, you’ll find remaining moisture and cleaning solution
litterally boiling up out of the surface of the metal. That’s the bad
end of the spectrum
With pewter, because castings solidify fairly slowly, and it’s cast
at modest temperatures, and doesn’t very aggressively oxidize while
melting (oxides that do form tend to form a slag, rather than being
mixed with the metal), it’s possible to get castings that are
generally quite good quality. Still, even microscopic porosity in a
cast item can be capable of retaining faint traces of foreigh
materials, including cleaning agents, or various patina chemicals,
or just the stuff hands come in contact with. The amounts of such
contaminants will be very small. But for people with sensative
allergies, sometimes this can be enough to cause problems.
The so-called noble metals, silver, gold, and platinum, are valued
for jewelry in part because of their relative lack of chemical
reactivity. One consequence of this is that they tend to not cause
allergic reactions. Pure gold, pure platinum, pure silver… very few
people are actually allergic to these. But that doesn’t mean it’s
impossible. There are a very few people who actually are allergic to
pure gold or to platinum. I even know one person who’s mother turned
out to be allergic to titanium. That’s unusual in part because
titanium is generally protected and isolated from it’s environment
(in this case, the body) by it’s ever present virtually impervious
oxide layer. In this case, it was a problem because she’d needed a
pacemaker, and the one they first installed, and then had to go back
and remove, had a titanium case, and it was discovered that she was
reacting badly to the pacemaker’s case itself.
As I said, Amery, you are the first person I can recall hearing
about who says they are allergic to pewter. But I’m not a doctor,
much less an allergist. That may simply mean I wasn’t paying enough
attention over the years, or more likely it simply means that this is
not a common allergy. Also, wearable pewter, such as rings, with the
metal in contact with skin, is less common than are silver or gold
items, so perhaps this seems like a smaller group of people simply
because few jewelry wearers are actually wearing pewter. In the end,
there are few materials that can claim to never cause an allergic
reaction. So even if pewter sensativity is rare, that doesn’t mean
you could not have such a sensativity. It may even be that you are
reacting to the copper or the antimony in it, rather than the main
metal, tin.
By the way, one side not more about demystifying pewter than
anything related to allergies. New workers in pewter are often
surprised that it doesn’t work harden. At normal room temperatures,
that temperature is close enough to the annealing temperature of the
metal, that it’s constantly able to anneal or at least stress relieve
itself. So it doesn’t work harden. In fact, cast pewter or a new
ingot is the hardest you’ll get. The more you work it, the softer
and stronger it gets. This is because as you work it, distorting
crystals, they recrystalize, so the more you work it, the smaller and
finer the crystal structure becomes. This is the same as working
silver or gold with repeated working and proper annealing, but with
pewter, it’s continually self annealing. You never need to. It just
keeps getting more and more workable as you form it. Very cool stuff
that way. And another cool bit. It’s a relatively poor thermal
conductor. What that translates to is that it’s wonderfully easy to
weld or fuse. To weld a seam between two pieces of pewter, or two
edges, etc, simply lay pewter chips along the seam, and with a tiny
flame such as the smallest air acetylene torch flame, or a little
torch, simply fuse those chips down into the seam. Planish it a bit
after cleaning up the weld, and the result is metal virtually
indistinguishable from the original metal, in either strength or
workability or look. It’s very cool stuff to work with. And for
model making where one wishes to get a vulcanized rubber mold, pewter
can sometimes be the ideal metal for model making. It’s easy to
carve, form, weld, and fabricate into your desired model, while
costing little in materials, and it’s strong enough, and has a high
enough melting point, to withstand being used with vulcanizing rubber
for a permanent mold. For very delicate forms it may not be as good,
but for others, it’s very nice material to work with. Just don’t get
it mixed in with your silver and gold working tools or area. That
invites disaster…
cheers
Peter Rowe
