You cannot imagine the amount of questions I have been getting on
this daylight box. I had no choice but to make this message so that I
can send to all of you.
This product can be used with any camera & software
- Indirect light. 2. Flat pure white surface 3. Shadowless 4.
No color interference
The Daylight box is made in USA of Unbreakable Molded plastic. It
uses indirect soft diffused light from 3 built in Halogen bulbs
(white light). The light bounces off the flat non glossy pure white
plastic surface of all the six sides of the box. You do not need a
flash or any other light source. This prevents any hotspots, gives
you a shadow less platform & you get a studio in a box feeling. The
Bulbs are of low voltage and the unit actually comes with a
Transformer.
It eliminates the use of a Tripods, Interfering Light Sources, Back
ground, Platforms. It fits on a small table top next to your computer.
Both your hands are free adjust the object with one hand and use the
mouse with the other. The cost is $440.00 HLS-6040B (check details
below) 6" x 4" light box complete with lamps, Power Supply, camera
mounting bracket, non reflecting stands for rings earrings and
elevated platform.
The Imaging software, the work area setup are two other important
things that will help you in getting consistant qualitty images with
ease.
I hope this answers your question.
Kenneth Singh -
To all interested in Daylight boxes:
(1) Kenneth Singh: who is your source? You give a stock # but no
vendor name. Perhaps it was cut off your post.
(2) I found a source at http://www.gripitlighting.com/light.htm -
much cheaper, but may not include all that you list in your post. Its
Sunday, so they are not open for business to verify what’s in cluded.
(3) Has anyone located other US sources?
thanks -
Ivy, in Oakland, CA where its dreary today.
What is the source of this daylight box?
You cannot imagine the amount of questions I have been getting on this
daylight box. I had no choice but to make this message so that I can
send to all of you.
The Daylight box is made in USA of Unbreakable Molded plastic. It uses
indirect soft diffused light from 3 built in Halogen bulbs (white
light). The light bounces off the flat non glossy pure white plastic
surface of all the six sides of the box. You do not need a flash or
any other light source. This prevents any hotspots, gives you a shadow
less platform & you get a studio in a box feeling. The Bulbs are of
low voltage and the unit actually comes with a Transformer.
computer. Both your hands are free adjust the object with one hand and
use the mouse with the other. The cost is $440.00 HLS-6040B (check
details below) 6" x 4" light box complete with lamps, Power Supply,
camera mounting bracket, non reflecting stands for rings earrings and
elevated platform.
ease.
Kenneth Singh
