Greetings!
If you are in the market for sturdy, well-designed Hydraulic Press
at a very good price, check out the new “Dakota Bulldog.”
It features: welded, all steel construction, 7.5 x 8 x 1-inch platens
upper platen drilled with 3 hole pattern to accommodate Bonny Doon
and other press accessories 2 x 4-inch uprights upper platen attached
to four enclosed return springs 2.5-inch diameter 10,000 psi gauge
with set and repeat indicator 20-ton Norco Jack heavy-duty steel
handle and release wrench fourth edition of Hydraulic Die Forming for
Jewelers and Metalsmiths
standard model (6.5" working height). $995. deep draw (10.5" working
height). $1095. (FOB Fairfax, SD-shipping and packing at extra cost)
I have been consulting with AutoTrac, Inc. to make sure it meets the
needs of jewelers and metalsmiths in every detail. including a good
price. I have a Bulldog in my studio and couldn’t be more pleased
with its performance. Check it out on their website
http://www.dakotabulldog.com
Susan Kingsley
