Hi: I would believe that would be a dilute mixture of nitric
acid and water (always pour acid into water) of a solution of
muratic acid (available in most hardware stores) will bring out
the pattern lines just takes longer. Hope I helped RINGMAN
JOHN HENRY
Kerry, No need to use anything so toxic as Oxalic acid. Ferric
Chloride is a better choice. Any store which caters to the
electronics hobbyist will stock it as “circuit etching solution”.
Here in the US I would recommend going to Radio Shack to
purchase Ferric Chloride…but I don’t know if you have Radio
Shack stores in Scotland? -Pete-
Hi, yes Oxalic acid will bring out pattern in Damascus steel.
You could also go to Radio Shack and buy a bottle of circut board
echant which is mainly feric cloride. Either should do the trick.
You may want to use heat with the Oxalic acid depending on the
concentration of your mixture. These also work well on
metiorites. The finish may come out rough and grey. If they do
just buff very lightly and maybe rub a bit of mineral oil on
them.
Hi, I thought as much! Thanks for the confirmation. I have ferric
chloride already in stock and I had forgotten about it’s effect
on steel but your reply reminded me of the time when I spilt
some on my mothers favourite stainless steel carving knife!
Regards,
Kerry
Kerry McCandlish Jewellery - Celtic and Scottish styles
Commission/Custom Work undertaken…http://www.bennie.demon.co.uk
Katunayake, Creagorry, Isle of Benbecula, HS7 5PG SCOTLAND
Tel: +44 1870-602-677 Fax: +44 1870-602-956
“Gun bluing” will color mild steel a dark grey with a hint of
blue. I’m not sure where you can get it–my dad had an old
bottle and I talked him out of it. If you find it, let me know
where!!
Judy, I colored an antique muzzleloading rifle using one of
those kits over 20 years ago and it is still pretty. These people
sell bluing and browning kits to make different colors: http://www.dixiegun.com/index.htm
Geo.
Judy you can usually find both gun bluing and browning at most
any shop that sells guns, or supplies. I bought some awhile
back at aBimart. I would think that shopko’s and most sports
shops as well. Check out the browning. it leaves a great
earthy brown on steel. There was a friend of mine about 6 years
ago that used the two on bronze castings. I was never able to
see the results, but she really enjoyed the colors that occured.
