I'm trying to colour my silver solder when I'm using silver solder
on copper I know you are suppose to add steel nails to your pickle
and the silver should become copper colour.
Lynne,
A couple points. What you are trying to do is essentially to copper
electroplate your work, so the silver gets copper plated. The nails,
or other iron, make this happen by setting up an electrolytic cell
due to the difference in elecrical potential between silver or
copper, and the iron. In order for that to work, it is not enough to
just have iron (nails, steel wool, etc) just in the pickle. It must
be also in electrical contact with the silver/copper you are trying
to color. It does not take much iron. Your steel wool likely is more
than needed, and since it not only acts as an electrode in your
reaction, it also dissolves in the pickle, it will cause the pickle
to become saturated with ferric sulphate. If it’s not in contact with
the work, then the steel wool will happily be plating itself with
copper, puling it from the solution, but not putting it on your
work.
Not a useful thing. You can do right with as little as simply using
an iron wire to hang your work, or carbon steel tweezers to
hold/suspend your work in the pickle (stainless steel doesn’t work,
so not all tweezers work), It doesn’t take lots of iron. And
remember, the iron MUST be in contact with your metal for the circuit
to form, and the copper to plate out on the iron.
Also, new pickle won’t work. It’s not the pickle that’s causing the
copper color to appear. It’s copper, plating out of the pickle, which
is just the electrolyte. The copper comes from the copper oxides that
have dissolved in the pickle from prior use in pickling sterling
silver, brass, copper, etc, So the process works with older, used
pickle. If the pickle is starting to look a little blue, it will work
very well. If it is new, you can substitute by adding some copper
sulphate to the pickle. This bright blue chemical, available
sometimes in hardware stores, is what would have formed in the
pickle from normal use over time.
One other comment is that one of the most effective methods to make
the silver solder not so obvious, is to make it less obvious. Dumb
statement, right? What I mean is very well fitted joints, and use
only as much solder as you need. When cleaned up, a good solder joint
should appear as only a thin line, not any sort of broad area. That
thin line is much easier to hide and color than sloppier, broader
areas of solder flowed out on the metal.
Hope that helps
Peter
