Hi ! I have been working, with a Model A by Roland for 6 months
but still some details I have to polish and develop, in order to
get a high quality wax piece. I fabricate a reduction the cutter
mouth, and adapt a foredom .5 mm round head cutter wish I found
to be the best for 3d models, because while the tool is going
down cutting the piece, it does not destroy the already cut parts
like with a cone shape cutter. I also find out that inputing the
software a smaller diameter tool helps a little to give a better
finish. Of couse always the draft and fine mode have to be used.
The issue is: I STILL HAVE TO HAND WORK A LOT THE PIECE AFTER IS
MACHINED, it has a lot of vertical and horizontal stripes, which
I have to file, but in the time I file, the piece loose its
original shape. My question is : Does any one knows how to left a
real smooth surface.
Hints: I’m using green Ferris wax , and in the software materials
I’m putting “chemical wax (hard)” I always use draft and then fine
mode. My cutting tool is a round head .5 mm, but in the software
i’m putting .3 mm
Gus
