solechristine.com
London, UK
Unique fine jewellery by Christine So, graduate of Central Saint Martin’s College of Arts and Design. The hidden secret collection features elegant earrings and rings made of 18ct gold plated sterling silver, multi-coloured sapphires, rhodolite and garnet. Some of the pieces hold a mobile element, which adds dynamics and versatility to the jewels. Combine with sensuality and sophistication, Christine So’s unique pieces are carefully considered from every perspective - form, function, detail and finishing are all well executed. Her collections are wearable, durable, yet playful, and certainly the one to watch.
Materials: Silver, rhodium plate and 10 multi colours sapphires
Rhodium plated ring surrounded by four layers of triangles
made by silver wire and sheet. All four layers can move around the ring
but only the middle two layers have sapphires set in. Therefore, when
you pile up the triangles, the stones are hidden safely in between.
You can easily show the stones by moving the triangles, also to create your preferred shapes and the way of wearing the ring
http://www.ganoksin.com/exhibition/var/albums/orchid/ChristineSo/7a.jpg
Triangle layered ring
You can easily show the stones by moving the triangles, also to create your preferred shapes and the way of wearing the ring.
![](https://orchid.ganoksin.com/uploads/db0786/original/2X/d/df101759398e30cee0cd08da1a39410c9874a65b.jpeg)
Trapezoid spinning ring
Materials: Silver, rhodium plate and 6 multi colours sapphires
Rhodium plated silver ring with an inside ring that
spins on axis points. The outer trapezoid has hand-rolled rocky
textures on the surface, whereas the inner round ring has 6 multi
colours faceted sapphires on half shank. Therefore, the wearer can
play and spin the ring to hide or show the gemstones. It is playful
and yet durable, which masterfully combines colour and texture to
arresting effect
Triangle stone earring
Materials: Silver, rhodium plate, multi colours sapphires, and purple rhodolite stones
Rhodium plated silver earrings with precious stones set on the inner surface of the “C”, which gives a shinny sparkling effect.
When you are wearing the earrings, people will be able to see the stones on the side and through the colourful reflections on the silver.
The designer blends the traditional craftsmanship with her passion for all things contemporary; the earrings are as dramatic as they are eternally chic.
![](https://orchid.ganoksin.com/uploads/db0786/original/2X/5/5af7c596860973ff94795d358aa55ce5e67808d5.jpeg)
Pentagon ring
Materials: : Silver, 18ct gold plate, rhodium plate and square garnet stone
18ct gold plated silver ring with a garnet stone set on the
V-shape rhodium plated silver, in order to reflect colour onto the silver. The ring shank is made by two wired rings, so as to create more space and detail to the design. It is a real eye catcher due to the combination and contrast of colours, this delicate designer ring would make a perfect jewellery gift.
Triangle turn ring
Materials: Silver, 18ct gold plate and rhodium plate
Half of the ring is gold plated and half of it is rhodium
plated. The triangle is designed to move around the ring, so that
the wearer can play and adjust in order to achieve the desired
appearance. When the triangle stops at the gold part, it will reflected
the colour onto the inside of the triangle. It can be worn as a pendant.
