With my Vacuum Casting unit broken, which is really a blessing in
that I never was confident that it would provide the expected
result…Was most likely due to the problem which caused it to
break!!.. the coupling between the pump and motor was just possibly
slipping on occasion.
I would like to build a shell or drum for a centrifugal caster… I
recall that there was a discussion material used per possible
contamination of the ‘splatter gold’ if reused in casting??
Thoughts as to how to make one and or materials to use… pic links
of home-made units would be appreciated…
Have considered purchasing the standard Centrifugal Casting
Drum/Shell … The Blue and Octagon shaped one in all catalogs… I
assume it is a baked on power enamel… Wonder if that flakes off
when Gold Splatter hits it??
But if gold 'Splatters'... will the Galvanized Metal contaminate
the gold???
No contamination, It works fine, been used for over 60 years just
scrape off the splash and get on with it. No problemo! All aloys
contain zinc anyhow and the cross over is not or ever been noticed.
Allan Creates
P.O. Box 51 Cote St-Luc
Montreal Quebec
Canada
Tel: 514-488-7553
Fax: 514-489-7299 Superringfit.com
Perfectly Fabulous Fit Arthritic Shanks
in that I never was confident that it would provide the expected
Just install your spinner inside a simple old style wash
tub. Bolt it down onto a solid bolted down table.
Allan Creates
There’s one thing about this that’s important to note: the
galvanizing on a new wash tub or sheet metal centrifuge enclosure
will stick to any metal that’s splashed against it. I had a really
hard time once, recovering some gold that soldered itself onto my
brand-new custom-rolled shell. As the zinc oxidizes, this becomes
much less of an issue. I ended up swabbing the interior of the
enclosure with vinegar, which seemed to abate the problem.
