Speaking of rolling mills, I have a 100mm Cavillin FC-110 with a
broken bearing. does anyone know a source of spare parts for these
mills? On line serches so far have not produced.
Jerry in Kodiak
Jerry in Kodiak
Jerry
Would you be able to email the image of the part with some
dimensions.
That would make it easy to search the product. Also location like
upper or lower right or left as in some older models there use to be
difference.
You can email me the image if you have it. [arjaninc at aol dot com]
Regards
Kenneth Singh
You might check with a local bearing house. Hardly anybody makes
their own bearings, and a bearing house will be able to look at your
old one and probably match it up with something from stock or a
catalog that will work fine.
