I have been hand fabricating jewelry for 40 years. And very difficult pieces in platinum for the top stores in the country.
I Think you will find that there are quite a few here that have
similar time at the bench and range of experience.
The difference in cast vrs. fabricated is distinct.
Yes the hardness and strength are quite different. As cast a typical
hardness of 18k yellow gold will be about 125 HV where wrought stock
in its fully annealed condition is about 150 HV so even after
soldering the wrought material will be harder and stronger than the
cast material. This is especially obvious in the modern cast
platinum rings that are so soft in comparison to fabricated platinum
rings.
Maybe after a few more miles under your belt you'll understand. The density is significant. Your answer tells me that you have not done very much hand fabrication in the noble metals.
If this was aimed at me I will say that I only have about 37 years
of jewelry making experience.
Otherwise you would understand the difference. Sorry for being blunt, but I don't want people who are trying to learn from these forums to be miss lead.
Just because you have a lot of time on the bench does not mean you
understand basic metallurgy. If you were to take for example a 18k
yellow ring that weighs 3.927 dwt as fabricated the same ring as
cast, with a quite a bit of porosity might weigh in at 3.853 dwt that
is a. 3 gram/cc difference in specific gravities and works out to
.074 dwt difference in weight. Yes you can measure it with a good
scale but you will not be able to feel the difference in weight.
Again as I said some of the mechanical properties are going to be
quite different between cast and wrought metal but the difference in
density will require a good scale to measure.
James Binnion
James Binnion Metal Arts
