Dear All,
I want to try the effects of kumboo on some jewelry and need to know
if the 24K gold foil can be too thin?
What I mean to use is the thin gold foil that is sold in Buddhist
temples to rub onto statues I have lots of packages I bought in
Thailand and Burma and would love to use them on my silver jewelry.
Any about this would be greatly appreciated.
Sharron enjoying her three day weekend due to a Buddhist holiday
to know if the 24K gold foil can be too thin?
Hi there,
There is a difference between leaf and foil. leaf (which is probably
what you have) is intended to be glued down using one of a number of
sticky materials (oil or water based sizing, or more modern,
verathane paints). Foil, which is what you need for keum-boo, is much
thicker than leaf. A test is, if you taouch it and it is still there
it is foil, if you touch it and it is damaged then it is leaf.
best
Charles
My grandfather was a bookbinder and I used some of his very thin 24K
leaf on jewelry. It is so thin it tends to fade into the silver and
looks rather green. I also folded the sheets together and, leaving
the folded sheets between tracing paper, I smashed them between steel
bench blocks then used the thicker foil for keum-boo with a richer
gold color.
Donna in VA
