Helpful hints on investment casting: troubleshooting casting problems
DEFECT - CAUSE - SOLUTION -
Cracking - Quenching too soon - Wait 15-20 minutes
Cracking - Metal cast too soon - Increase casting temperature
Cracking - Flask too cold - Increase flask temperature
Cracking - Incorrect sprueing - Modify sprueing
Cracking - Contamination of gold or alloy - Refine metal
Cracking - Oxide build up in metal, over-use - Refine metal
Cracking - Hydrochloric acid di-vesting - Use alternative di-vestor
Incomplete fill - Metal too cold - Increase casting temperature
Incomplete fill - Flask too cold - Increase flask temperature
Incomplete fill - Insufficient vacuum - Check vacuum for leaks and
seal
Incomplete fill - Wrong speed on centrifugal caster - Adjust speed
Incomplete fill - Insufficient burn out - Modify sprue
Incomplete fill - Incomplete burn out - Use proper burn out schedule
Inclusions in castings - Sharp corners or bends in sprueing - Round
out sharp corners and bends
Inclusions in castings - Crucible old and deteriorating - Replace
crucible
Inclusions in castings - Oxide build up in crucible - Clean or
replace crucible
Inclusions in castings - Foreign particles or oxides in metal -
Refine metal
Inclusions in castings - Investment erosion or breakdown - Follow
investment manufacturer’s mixing instructions
Brittle prongs on castings - Improperly alloyed metal - Pre-allay
gold and master alloy
Brittle prongs on castings - Flask temperature too cold - Increase
flask temperature
Shrinkage prorsity - Incorrect sprueing - Sprue to heaviest area of
casting
Shrinkage porosity - Inadequate sprueing - Use larger sprue or
multiple sprues
Shrinkage porosity - Flask too hot - Use lower flask temperature
Shrinkage porosity - Castings too close to sprue button - Leave 1"
space on tree above main sprue button
Gas porosity - Metal overheated - Reduce casting temperature
Gas porosity - Inadequate burn out - Increase top end burn out time
Gas porosity - Inadequate air supply during burn out - Assure oven
has good air supply & exhaust
Gas porosity - Flask too hot - Reduce flask temperature
Gas porosity - Scrap reused too many times - Refine metal
Gas porosity - Too much oxygen on torch flame - Use reducing flame
when melting
Gas porosity - Investment residue on remelted scrap - Remove
investment residue before remelting scrap
Rough castings - Flasks not cured before burnout loading - Let
flasks set 1-2 hrs. before burnout loading
Rough castings - Incorrect water-powder ratio in invest. mix -
Follow investment manufacturer’s instructions
Rough castings - Flasks heated too rapidly - Follow investment
Bubbles/nodules on castings - Investment not mixed, vacuumed or
vibrated sufficiently - Follow investment manufacturer’s
instructions
Bubbles/nodules on castings - Vacuum pump not working properly -
Check vacuum pump oil level and
Bubbles/nodules on castings - Wax patterns not coated with wetting
agent - Coat wax patterns with wetting agent
Andy The Tool Guy
