Colouring brass.
I used to be able to get brass model railroad wheels with a 'rusty’
effect. The finish was a matt powdery effect with a slightly red
coffee colour. Do you know how I can replicate this finish as they
are no longer available?
Colouring brass.
Colouring brass. a matt powdery effect with a slightly red coffee colour
Hi, two ways- ( although not too sure about the powdery bit, the
first one says semi matt,the second semi gloss)
immerse in boiling solution of 1litre water and 25 gms of copper
sulphate until colour looks right, then place in some hot water while
you add .5 gm ammonium chloride to the original mixture. Re immerse
in the mixture for 10 mins, remove and rinse in hot water. or…
heat with your torch and apply mixture of 10gms ferric nitrate to
1 litre of water. recipes courtesy of the " patinaters bible" The
Colouring, Bronzing and Patination of Metals" by Hughes and Rowe have
fun, be careful, don’t breathe in any fumes,
Christine in S Aust
Hi Pete,
Have you tried www.micromark.com? They have some things that make
various materials look rusty.
Lisa
Designs by Lisa Gallagher
www.designsbylisag.com
Hey Pete,
Just a thought… try citadel paints, (a miniature paint) I like
chestnut ink for a rust color and spay a Matt finish on it. should do
the trick … Good luck
Happy profits
Sean
