I hope someone can help me with a problem I have been trying to solve
forsome time now. I am trying to attach borosilicate glass beads or
buttons to a piece of sterling to create a pendant or earring. I have
tried the following without success:
Soldering a wire to the sterling, placing the bead through the wire,
protecting the bead with heat sink or something similar to keep the
glass cool, and balling up the end of the wire. The bead didn’t make
it, and even if it had, the ball would have needed cleaning up and
pickle would have broken the bead.
Riveting a wire to hold the pieces together. I couldn’t find a way
to do this without cracking of chipping the bead as I used the hammer
to make the rivet. Pre-balling the wire, and placing the bead and
sterling through so the wire comes out the back of the piece. For an
earring, I tried to run the wire up the back of the sterling to make
a hook for the earring, but the piece wouldn’t stay firmly
"sandwiched" together, and the weight of the material made the
earring fall forward when placed in the ear.
I am at a real dead-end and any help would be unbelievably
appreciated!!
Thanks,
Tracy
