I made a palladium ring with a 9ct white gold band soldered around
the middle, the customer has had it about two weeks and it now has
black marks showing!! Picture below! Any idea how it happened or
what it is and best way to get rid of, I assume filing it off but is
it just a surfacereactione Thank you in advance!!
black marks showing!! Picture below! Any idea how it happened or what
it is and best way to get rid of, I assume filing it off but is it
As mentioned in my previous post, the photos are too small to see
the actual problem, but it occurred to me later that you might have
fallen into the Pd solder trap. The composition of the only two Pd
solders available from Cookson’s here in UK are:
Easy - 800-850C, 12% Au, 47% Ag and 17% Pd
Med - 870-940C, 89.8% Ag, 4.6% Pd.
If you use Medium, then its nearly all silver, and silver is turned
black by some people.
Here is a better picture, the solder may be the problem as it is
where the two metals meet, this is the worst mark of the three, so
filing would remove the excess then?
