What do most of you use for making bezels? Something you order, ie,
pre-made? Somethng you cut from sheet? Something you roll thru the
mill? All of my work is fabricated. I have been using bezel wire I
ordered. I have ordered from both Hoover and Strong and Hauser and
Miller - fine silver and 18 and 22 k gold. I am not happy with the
results and I strongly suspect it’s not the bezel wire but my
technique. I have also cut strips from sheet and find I spend an
inordinate amount of time straightening the strip with my files,
sanding disk and sanding paper, etc. I have tried rolling wire thru
the mill but still have to sand or file off the rounded edge on one
side - again very time consuming. I rarely use a prong setting so
this is the way I ordinarily set my stones or enamels. I had been
using the bezel wire I could order because it was easy and relatively
thin and didn’t put too much pressure on the enamels. I use hard
solder both to create the bezel and to solder it to sheet. However,
by the time I have finished all the other soldering I often end up
with visible seams on the bezel where the solder has receded
slightly. I had learned to leave a ledge beyond the seam wherever
possible (to be removed with the saw later) to prevent this but it is
not often possible as the bezels are usually at the center or
scattered around the piece and not at an edge which can later be
removed. Do any of you have any suggestions? I normally do all or
most solder operations with hard - hard silver or hard 18k plumb (also
purchased from same suppliers) waiting until the findings to use
medium or rarely, if I have alot of soldering, move earlier to medium
and finally easy for findings. I usually use a white paste flux,
(tho sometimes its the yellow batterns) often but not always coat
with firecoat and occasionally use whiteout on earlier seams. What am
I doing wrong?? Any suggestions or help would be greatly appreciated.
Sherry
Sheridan Reed
Sheridanreed@cox.net
