I have a question that maybe someone here on Orchid can help me with.
Some of my customers (retail jewelers) really seem to like shallow tapered bezels, especially as dangles for earrings or as a design element.
(Stuller #574 is a perfect example of these bezels)
Has anyone a trick or technique for holding these very shallow, but tapered bezels while setting stones in them, when they are not already soldered in place where the piece itself cannot be used to hold them while setting?
Because these bezels are extremely shallow they are always extremely difficult to hold onto when trying to set a gem in them, if to be used as a design element to be attached later.
I have tried using setting shellac and thermo plastic, but the bezels usually spin right out while cutting seats, so this seldom works out for me.
For several years I have been using the barrel of an old Sterling Silver, Parker ball point pen for holding some of the larger bezels. With the pen barrel soldered to a bezel I can use the pen barrel to hold the bezel while setting the gemstone. I then have to cut away the solder, and a bit of the pen itself, especially if the gemstone will not take the heat of unsoldering it afterward.
This technique has worked, but is very time consuming and wasteful, and I was hoping someone else might have a better suggestion than I have come up with.
