Hi All
I’m hoping one of you experienced folks can help me…I’ve done
lots of silver & gold soldering but always used a “juiced up” version
of a butane torch…big flame plenty of heat everywhere (you get the
idea). I now find the need to heat smaller areas using tiny flames so
I’ve bought a Rothenberger Roxy Kit Plus Oxygen & Propane mix which
has lots of needle tips.
Firstly I connected all the hoses & can’t hear any hisses (yay - I
think, onto the next section of the instructions, yes I’m a girl I
read the instructions) Then is says to open the Maxigas 400 about 1/2
a turn and ignite the flame…this was quite alarming as the thing
suddenly sounded like I was letting air out of a balloon whilst
pulling the neck (a loud rubbery squeaky sound) is this normal? I’ve
turned it off for now as I dont want to blow myself up…
So can anyone help, plus can anyone suggest the best tip size for
instantly balling 1mm sterling wire without the surrounding area
gettig too hot? I have 0.3, 0.4, 0.5 & 0.6 tips
Thank you in anticipation
Nicola xx
http://muranosilver.blogspot.com
