john16
1
Hi, folks. What in your experience is the best solder for the
following tasks in order to make the solder line as invisible as
possible:
Soldering bronze to bronze–either commercial bronze or silicon
bronze;
Soldering bronze to stainless steel;
Soldering yellow brass to yellow brass;
Soldering sterling to bronze;
If you could be as specific as possible on the solder and where I
can buy it that would be great. Thanks.
I’ve used hard silver solder with bronze, and brass, and the seam is
barely detectable.
The brass was a yellow brass, but the bronze was 90/10.
I’ve also soldered fine silver to 90/10 bronze with hard silver
solder, but it was a sweat solder so a seam wasn’t an issue.
I also did a mokume of fine silver and 90/10 bronze, but used no
solder, just heat and a hammer.
Regards Charles A.
Hi,
Rio Grande has a gold filled solder that works very well on brass.
The joints don’t show at all.
http://www.ganoksin.com/gnkurl/92
I hope this helps.
Linda
Owner/Designer
www.beadmeus.com
