Hello David & Gerry - Your points are well made (and taken). Proof
once again that there are many ways to accomplish similar tasks. To
help eliminate the spring in Jett Set, I will integrate metal into
the jig. I also use a bench mate by GRS, and by removing the plastic
pieces from the ring holding clamp, and making my jigs with as little
Jett set as possible, I can eliminate most of the spring. Personally,
I like the fact that Jett set does not stick to my pieces. If I have
a fragile stone to set in a piece that needs holding, I will cut the
seat first, then mostly finish the piece before finally setting the
stone. I can make the jig before the stone(s) goes in, and make it in
a way that allows me to easily remove the piece after setting. I also
use it on pliers as an anti marring agent, and as a way to hold
pieces easier. For example, I make a piece that has one stone set in
it, and it is very small. If I am doing one, I will hold it in my
fingers to cut the seat and set the stone. However, if I have many to
do, (which I almost always do at least 6 at a time), then the fingers
take a beating. So I made a little Jett set jig that fits on the end
of one side of round nose pliers. I can then put one end of the
pliers through the chain opening, and the end with the Jett set locks
the piece easily in place with little hand pressure. Now I can set
the piece easily, and much faster.
I have also used Jett set for non-jewelry things, like - replacing a
broken screw driver handle, an air line valve on my compressor, a
knob on my clothes washing machine, and many other things. I just
think it is handy stuff to have around. And since I never really
liked shellac, (the smell rubs me the wrong way), I found a way to
adapt Jett set to serve the purpose for me.
I suppose it is all about technique, and what is comfortable for you.
I like to try new things, and new ways of doing things. If I think it
will save me time and/or money, I will try it. I have a laser, and
love it. However, sometimes good old fashioned soldering produces the
best results.
I also want to say thank you to people like David, Gerry, and Jim
Binnion for freely sharing your knowledge. Although I have little
time to participate in this forum, I do appreciate the variety of
perspectives it offers. It is always nice to know that I am not alone
in my little forrest, and reading Orchid helps me see through the
trees.
Kindest regards,
Stuart J. Adelman, Designer
ArtelleDesigns.com President,
Contemporary Design Group 2002-2004
artelle07@aol.com 763.559.0044
