This soldering board from Cooksons looks very similar and I have been
using it for some years, it is soft enough to stick in binding
wire/pins or cut and shape but it does not seem to come in sheets as
big as those on the vidio
When in the the state of charcoal block unevenness, it’s a Capitol
idea,to "sand the sucker on a cinder block or a similar concrete
surface. To smooth the heat affected “Thang”…sanding is the
key…
Wrap the block with binding wire prior to using it for the first
time, As it is said here in the Bay Area " helps keep it together,
man"
During the season, let’s not make turkeys out of ourselves
When in the the state of charcoal block unevenness, it's a Capitol
surface. To smooth the heat affected "Thang"..sanding is the
key.......
Another good surface to sand it on is a sidewalk.
When sanding move it in a figure 8 pattern. That motion will tend to
keep the thickness even from side to side.
This works equally well for firebricks when their surface gets dirty
&/or uneven.
key.......
yeah, did it - its very easy & very effective, isnt it!
