Hi Gang,
I looked at some of the new shop vacs that were displayed in
Home Depot & Payless Cashways. The vacuum inlet on most of these
goes in the side (90 deg to the top) of the top cover. The
instructions I listed recently for converting one of these for
use as a water bath vac won’t work. The following instructions
will.
Many of the newer, larger shop vacs (10 gallon & up capacity)
have the vacuum inlet on the side of the top cover. The cover has
a molded deflector on the inside of the inlet. This deflector
must be removed in order to modify the vac for use as a water
bath vac. This modification will reduced the effectiveness of the
vac for ordinary vacuuming if it is used for both applications.
I saw one vac that had the side inlet, but no deflector. It was
mfgd. by Ridgid, model WD1200, priced at $69.95 at Home Depot. It
is a 4.25hp, with a 12 gallon capacity & comes with a full set of
tools.
All the vacs I saw had a 2 1/4 inch inside diameter inlet hole.
It will be necessary to obtain some plastic plumbing fittings &
pipe to complete the installation. A 1 1/2 in PVC 90 deg elbow
has an outside diameter of 2 1/4 inches. This can be cemented in
the inlet with standard plastic plumbing cement. A 24 in long
piece of 1 1/2 in PVC pipe is also required.
Here’s the instructions for those vacs that have the inlet port
on the side of the top cover and a deflector as part of the
inside portion of the inlet port.
Dave
Section I
Remove the top cover.
Empty the contents of the tub into the trash & clean out
the tub as required. -
Cut the inlet deflector from the inside of the top. A
sharp knife may be repeatedly drawn along the intersection
of the deflector with the top cover until the deflector can
be removed. A hack saw blade, with one end taped for a
handle, could also be used to saw the deflector off. Follow
the contour of the cover when removing the deflector. -
Remove any burrs & rough edges with a suitable file or
sandpaper. -
Insert the 1 1/2 in elbow into the inlet hole from the
inside to check for fit. It may be a little loose. If the gap
is less than an 18 ga wire, the plastic cement will fill the
gap. Mark this end. -
If the gap is more than an 18 ga wire, a few wraps of
black electrical tape can be placed on the elbow. Wrap the
tape as far back as possible & only 1 tape width wide. -
Remove any burrs or rough edges from one end of the 1 1/2
in PVC pipe. Mark this end. -
Insert the marked end in the untaped side of the elbow.
Insert the elbow in the inlet hole. Be sure the pipe is
pointing straight down (perpendicular to the vacuum top). If
the bottom of the tub slopes in too far to allow the pipe to
remain perpendicular to the top cover proceed with the
instructions in Section II. -
Carefully set the top on the vacuum. It won’t be able
reach it’s normal resting place because the pipe is too long. -
Measure the distance from the top of the tub to the
bottom of the top right at the inlet hole. -
Remove the pipe & elbow from the inlet hole.
Remove the pipe from the elbow.
Add 1 1/2 inches to the measurement from step 11.
Transfer this measurement to the unmarked end of the pipe. -
Cut the pipe at the mark & remove all burrs & sharp
edges. -
Clean the end of the pipe that fits into the elbow of
all dirt, oil & grease. Note: A cloth with acetone or alcohol
works well for this activity. -
Clean the outside of the taped end & inside of other
elbow end of all dirt, oil & grease. -
Clean the inside of the vacuum inlet hole of all dirt,
oil & grease. -
Apply a liberal coating of PVC cement to the inside of
the untape end of the elbow. The cement should cover the
entire inside, from the ridge to the end. -
Apply a liberal coating of PVC cement to the marked end
of the pipe. The coating should cover the entire surface of
the pipe for about 1 in back from the end. -
Insert the glued end of the pipe into the glued end of
the elbow with a twisting motion. Hold the two together 10-15
seconds after the pipe is seated. -
the vacuum inlet. Try not to get any on the potion of the
inlet the vacuum hose connects to. Any excess can be wiped
off with a paper towel. -
Apply a liberal coating of PVC cement to the outside of
the taped end of the elbow. -
Insert the elbow into the vacuum inlet. Be sure to
position the pipe so it’s hanging down, perpendicular to the
top. Hold the elbow & top in position for 10-15 seconds after
the pipe is in the correct position. Place the top on the tub
to allow the cement to dry. Be careful not to move the pipe
while replacing the top. -
Follow the directions on the cement container to
determine drying time. -
If any gaps appear after the cement dries, they can be
filled with silicone bathtub caulk. Let the caulk cure before
apply any vacuum.
Section II
If the sides of the tub slope in at the bottom too far to
allow the pipe to extend straight down from the elbow, an
extension may have to be added to the part of the elbow that
goes into the vacuum inlet.
This can be accomplished as follows:
Obtain a 1 1/2 in PVC coupling, mark 1 end.
Cut a piece of 1 1/2 PVC pipe 2 inches long. Remove any
burrs & sharp edges. -
Measure & record the length of the vacuum inlet (inside
to outside). -
Clean any dirt, oil or grease from the inside of the
marked end of the coupling & long pipe, the elbow & the 2 in
long piece of pipe. Note: A cloth with acetone or alcohol
Apply a liberal coat of PVC cement to the inside of the
marked end of the coupling. -
elbow. -
Apply a liberal coat of PVC cement to both ends of the 2
in long pipe. -
Insert the 2 in long pipe into the glued end of the
coupling with a twisting motion. -
Insert the pipe with coupling attached, into the elbow
with a twisting motion. Hold the assembly in position for
10-15 seconds. -
elbow. -
Apply a liberal coat of PVC cement to the marked end of
the long pipe. The cement should cover the entire outside of
the pipe aprox. 1 in back from the end. 1. Wait at least a
1/2 hour for the cement to cure before continuing with the
next steps. -
Insert the coupling into the vacuum inlet from the
inside. Check to see that the elbow end does not interfere
with any part of the vacuum. Check the fit as in steps 5 & 6
in Section I. Also measure the distance between the outside
end of the coupling & vacuum inlet. The assembly should be
inserted in the inlet far enough to allow the long pipe to
reach the bottom of the tub without contacting the side of
the tub. -
Check to see the measurement from step 12 is less than
1/2 of step 3. -
If the the result of step 13 is more than 1/2, cut the
excess from the coupling. Remove any burrs or rough edges. -
Insert the coupling in the inlet hole. Be sure the pipe
is pointing straight down (perpendicular to the vacuum top). -
bottom of the top, right at the inlet hole. -
Remove the pipe assembly from the inlet hole.
Add 1 1/2 inches to the measurement from step 17.
Transfer this measurement to the end of the pipe… -
edges. -
Clean the outside of the coupling of all dirt, oil &
grease. -
oil & grease. -
the coupling. -
28 Any gaps that appear after the cement has hardened can
be filled with silicone bathtub caulk. Be sure to let the
caulk cure before subjecting it to a vacuum.
