Tim McCreight s complete Metalsmith" has some plans w/layout
dimensions for a workable first bench. When adjusting to your height
if you stand with your hands down at your sides and outstretched,
that is the height to start with.
Look through the bench exchange to get some ideas on the frills so to
speak as each bench is rather unique in some way. as for the sweeps
tray remeber if you use any clamp on bench pins, vises, etc. that any
rails you add to the underside of the benchtop will be impeded by
anything you clamp or bolt to it…so add three inches minimum to the
distance from the top of your bench to the distance you set your
sweeps tray. I personally like an archaic style leather apron that is
attached to the bench and my neck when I pierce or saw materials.
The sweeps tray in my bench is more a shelf at this point as the
apron is easier to reclaim dust from, and larger trimmings and sweeps
are brushed up easy enough…It’s all a matter of taste and design
necessities. I had a professional woodworker build my main bench with
a mounting plate off center for the GRS benchmate’s mounting plate so
that it is not in the way of other pins, mandrel holders, etc…
just inventory your equipment that you use most - be it a certain
style bench pin and it’s mounting apparatus, a GRS benchmate system,
your flexshaft and stand, micromotor, microscopes, etc, then work
from there in your design - Don’t rush into anything without
considering all the elements you need at hand, what can be put on a
different surface or in a different area( as space dictates, you may
have seperate soldering pickling areas, polishing areas,
casting&melting areas, a stump for your anvil, rolling mill and
hydraulic press on movable stands to which the tools are bolted,
etc…).
Everyone’s space and needs are different. Lighting, electrical
outlets, water source, tank area, compressor and air tools, kilns,
heating and cooling, air circulation, and storage all affect how you
set up your bench or larger studio area. So me telling you to make
the sweeps tray 18 inches below the top of your bench is only
relevant to my bench, which has a traditional arced top with some
shelves at head height.
Most benches are more like table tops flat across the top so it is
relative to what your needs are, tools and equipment you use most and
want at hand, and the amount of space you have to dedicate to jewelry
making as to what you need in a bench. I know a very experienced
goldsmith that prefers an office table to his bench ; he has three
benches in his studio and each is dedicated to different
operations…so back to Complete metalsmith, looking through
catalogues and styles to arrive at what serves you the best…
