Ball pins, what is the trick?
Hi to all
I want to thank everybody who answered my previous posts. It helped!
Today, I tried to make headpins by melting the tip of dead-soft 26
gauge wire with a torch. Well, most of them ended up all crooked at
the end, while some were nice. What’s the trick ?
Also, I put them in a pickling solution after, and then polished
them. Tough… I don’t have a tumbler, so is this method okay ?
Thanks again
cecile
Cecile. When I make headpins/ball pins, I snip small pieces of metal
(SS, 18k, AS, fine) & fuse them into balls. Then I take my length of
round wire (22, 24, 26 or 28 ga) & place it next to the ball-they’re
touching.
With my Blazer hand held torch I use a flame a little hotter than
annealing & heat both wire & ball evenly-they fuse pretty quickly.
The ball will actually jump towards the wire. If I don’t remove the
flame, the ball will roll up the wire. I used to just heat the ends
of wire but didn’t like the inconsistancy & the tendency towards
oddly shaped balls. The method I use now nets me almost 100%. If you
can, you really must invest in a tumbler, it will have paid for
itself within a month. A small Lortone tumbler run’s about $50-I
think, it’s been more than 10 years since I bought mine & will make
your life so much easier. I can’t imagine hand polishing headpins-it
must take you hours. I toss mine into the tumbler (after pickling) &
viola! 20 minutes later I’m good to go. Word to the wise-never
tumble headpins with chains. I learned that lesson not to long ago.
It gave me a great idea for a piece, after I spent 3 hours removing
200 18k headpins from a long 16 ga 18k chain.
Be well, do good work,
Cristine McC
Hi Cecile,
I was having the same problem and found some good suggestions with
an Orchid archive search. Look at this thread:
https://orchid.ganoksin.com/t/balling-up-sterling-silver-wire-rough-look
Mike DeBurgh, GJG
Henderson, NV
If you’re making a LOT of them, you might wish to make a jig. Find
(on ebay, or elsewhere) a chunk of graphite block as thick or thicker
than the total final length of the head pin you wish to make. Drill a
hole that’s a somewhat loose fit for your wire to the depth of the
wire portion of the headpin, and use a ball bur or cone bur or
something of the sort to bevel the top edge of the hole. not a lot,
but so the countersink is almost the size of the ball you’ll want.
To use, cut your wire to the length you’ve determined is
appropriate, and drop it in the hole so a bit sticks up. Graphite is
an exceptionally good heat sink, and will keep the length of wire
that’s IN the hole, virtually cold, or at least, not much warmer than
the graphite block itself. Put a tiny bit of flux at the tip of the
wire before putting the wire into the hole. You’ll then need a torch
with a good hot flame (oxygen/fuel, not just a plain propane or
blazer torch). Because the graphite is a heat sink, you’ll need a
flame hotter than you might expect. Point it straight down at the end
of the wire, towards the graphite block. If you’re using the right
flame, the end of the wire will ball up almost instantly, dropping
down to not quite touch the graphite, and the ball will remain
centered by that countersink you cut. It will chill almost instantly
when you remove the flame, and you simply pull the resulting headpin
from the block (use tweezers, 'cause the block will become too hot to
hold in your hand after a few of these), and do the next. try to
avoid flux on the graphite block itself, as that will gum things up
and glue the pins to the block. So apply the flux to the tip of the
wire before dropping it into the jig.
You can also make such a jig from considerably thinner graphite
sheet. I’ve made them from 1/4 inch thick graphite sheet. This allows
you to make any length of pin you wish, but then you’ve got to hold
it in some sort of third hand or other arrangement, so the length of
wire is determined by what the wire hits underneath the graphite.
Graphite is a bit slippery to hold in tweezers, so getting this set
up to work can take a bit of jerry rigging. But the thinner graphite
is cheaper to buy, and the end result is just as good.
The beveled hole edges eventually get a bit too burned, and then you
simply drill another hole a quarter inch away. Or with the thinner
graphite sheet, flip it over and use the other side.
I was recently doing something similar, smaller balled ends than
most headpins, on short gold wires for nose studs. Because I was
balling up the end of the wire after a bezel had been soldered to the
other end, a simple hole wouldn’t work. So instead, a fairly tightly
fitting slot in an edge of graphite sheet, also beveled to a slight
cone at it’s inside end, did the same thing. With that, the wire was
slid into the slot from the side, and the thickness of the sheet of
graphite also regulated the length of the finished stud. After
balling up the end, it could simply be slipped back out the slot. The
slot was made to a snug fit so friction would hold the wire in place
while being balled up. That was an order of over a hundred pieces
like that, and by the end, the graphite was just beginning to show
some heat effects, but had a lot of use still ahead before it would
need to be remade.
Hope that helps.
Peter Rowe
Hi Cecile,
You might try Argentium silver for headpins. I have found that it
makes large perfect smooth balls very easily.
Dip the end of the wire in liquid flux, hold torch so flame is
pointing straight up, hold wire in tweezer so end is straight down,
and lower the fluxed end of the wire into the cool pointy end of the
flame. Watch as the ball forms and crawls up the wire and remove from
flame once desired size is reached. Pickle and tumble.
If you stay in the flame too long the ball will get too big and melt
off, so you may sacrifice a few to learn how large you can make them
for your wire size. Argentium melts too fast in the hot part of the
flame, so stay in the cooler tip area where you will have more
control. If you need to make a lot of them, set up a clamp-on vise
to hold the torch.
Vera
Hi Mike and Cecile,
I was having the same problem and found some good suggestions with an
I read all of the threads at the link you sent and I didn’t find the
way I do it. Now I only use Argentium wire when I want to ball a wire
as it looks like a little pearl on the end but when I was using
regular sterling wire I would use my Oxy-propane Little torch and
hold the wire in the third hand pointing down. As soon as the ball
would begin to form, I would turn off the oxygen and hold the
propane flame on it for another second or two and I was always able
to get a nice smooth ball that way. Several of the people who posted
were mainly doing the same thing but just in a little different way
by cooling the flame. By the way I read that somewhere but did put it
to good use.
Lona
