Hi Jennie,
You know, I've been using a lot of Argentium, too, and recently
got a letter from a guy because he had an allergic reaction to the
Argentium -- turned his finger black and caused a contact
dermatitis. Just out of curiosity, which mill are you getting yours
from?
No matter who you buy your Argentium Silver from in the U.S., it is
ALL made by Stern-Leach. Stern-Leach has the only license to make
Argentium Silver in the U.S. The people you buy from are
distributors. (I have, however, heard from a few people who bought
silver that they were told was “like Argentium”----these alloys
turned out NOT to be like Argentium Silver, after all,
though----they had problems, which was why the purchasers contacted
me with questions.)
Remember that there can be lots of reasons for problems. For
instance, one former student wrote to me with concerns about
hardening her AS. Finally, she realized that she’s been clapping her
hands at musical performances, and that the AS ring was getting
clapped against diamonds and platinum! We tend to blame the new
material, but we need to be detectives, and look further, sometimes.
I wonder, for instance, if the guy who had contact dermatitis got
soap caught under the ring. He may need to take it off and rinse and
dry well when he washes his hands—especially if the ring has a wide
band.
I am fastidious about cleaning my jewelry prior to sending it out
-- I don't soak it in ammonia for days, but it is soaked in it for
about 30 minutes then brushed thoroughly, then scrubbed with dish
soap and rinsed and dried.
The only reasons I can see for soaking in ammonia are to take off
polishing compounds and to neutralize pickle. So, if you’ve already
removed polishing compounds, baking soda would do just as well at
neutralizing, and smell better. If the polishing compound is
removed, then the dish soap and scrubbing and brushing are not
necessary either—simple rinsing would be adequate. I would be
careful about excessive scrubbing, which could abrade the
tarnish-resistant germanium oxide.
I have wondered if there is a trace of copper in it that can do
this. I’d love some input, too! There is more than a trace of copper
in Argentium Silver—Argentium Sterling is about 6% copper. Copper
is what gives the alloy strength. (Compare to fine silver to see how
much farther sterling alloys can be pushed than pure silver when
forming, forging, or rolling.) To avoid having copper on the surface,
which can cause skin discoloration or other reactions, it is helpful
to have heated and pickled several times. Here is a sequence I would
suggest for “ultimate” tarnish resistance: -Heat and pickle several
times (this usually happens naturally during the process of making
something.)
-After any abrasive processes, such as polishing, or filing to
remove solder, heat and pickle again. Ideally, this is hardening in
the oven, but if there are stones set that cannot handle that heat,
10-30 minutes in a toaster oven at 250 degrees F (or less, if
necessary, such as for pearls) accelerates the creation of germanium
oxide.
-Pickle after heating or hardening to remove any copper on the
surface. (Neutralize, rinse, and dry well after pickling.)
-If you use steel wool or a brass brush, be sure to use with soapy
water, so that the steel or brass burnishes without abrading and
without transferring to the surface of the silver.
-For additional tarnish “insurance”, rub the surface with a cloth or
compound that contains thiols, such as Goddard’s Long Shine Cloth or
Polishing Compound. Thiols are a chemical that add further tarnish
resistance. One person I know uses Goddard’s Long Shine Liquid on
his buffing wheel for the final polish.
Note that most of the above is optional. Germanium oxide forms at
any temperature above freezing. Any higher temperature accelerates
the formation of the tarnish-resistant germanium oxide. So, if there
are pearls or amber, even 100 degrees for a couple of hours and then
a Goddard’s cloth would add tarnish resistance.
Cynthia Eid
