Let me begin by saying that I really want to like argentium
sterling, but I just can’t-in my experience so far it’s been a bit of
a PITA to work with. In fact, as a running joke in the studio where I
work, we have an “I Hate Argentium Club,” of which I am now an
official member-and these sentiments come from a couple of goldsmiths
who have decades more experience than me, who use the stuff pretty
frequently. That being said, I’ve been experiencing some weird stuff
lately that really has me wanting to throw some of those stress-ball
thingys at the wall.
As I mentioned, I’ve been using argentium pretty frequently at work.
In my latest escapade, I’m working on a really quick and simple
hammered chain that I’ve made before out of the same argentium. Specs
are as follows:
… 18gge AS wire
… Chain link surfaces are flush and butt together perfectly and
with adequate tension
… Fluxed the seams (actually I tried this with and without)
… Using a size 0 torch tip on a Hoke handpiece w/natural gas and
oxygen (have tried larger torch tips too)
… Pick-soldering with medium AS solder (tried fusing too, to no
avail)-pick-soldering was fun. ::
… I am NOT trying to heat the entire link (as with regular
sterling), but I have also tried heating the entire link, both with
the same results
What the argentium is doing that I find really weird is
shrinking!!! -By up to 1/3 of its original link diameter! And when
the links shrink, they don’t shrink in uniform circles.
I’ve made almost every kind of adjustment I can think of, and my
success rate has been less than 50% this time around. -Now I KNOW how
to solder for crying out loud, and if I had been doing this in
regular sterling it would have taken me all of about 20-30 minutes
tops to knock out all of the links I needed for the day. I won’t
embarrass myself by revealing how much time I spent on a handful of
links today-we were all stumped by what it was doing.
Any thoughts as to what the deal is? I didn’t have this problem
before, so I suspect that perhaps the alloy is just bad? I mean
this stuff moves like it’s alive. And what it’s doing is wanting to
ball up (even from wider-diameter links), which makes it sound like
I’m applying too much heat-but again, I haven’t had this problem
before now. Also, the perfectly-butted joints seem to want to come
apart by a millimeter or two during the process (don’ tell me I HAVE
to anneal them after winding and cutting them so they don’t do that?
-I’ve been able to work argentium pretty far in most cases before
needing to anneal (this just crossed my mind, so I’ll try that
next)).
Any thoughts on what I might be doing wrong?
[I bought some argentium that I was going to use for my own stuff for granulation (I bought sheets of the stuff), but I’m about ready to hurl it out of the window…]
This is not to read as bitterly as it sounds-my comments here are
meant more in jest, and simply I’m more puzzled than anything else. A
little less than happy that so much time was spent on this with
unsuccessful results? Sure.
Thanks in advance.
Tamra Gentry
http://gentrydesignco.typepad.com/jewelrydesignchronicles/
