Again some casting problems
Hello,
I have casted some Solidscape prints with the following result (see photo).
What could be the cause?
And another issue…
After burning out the prints, I always have a dusty surface on the button hole.
Looking forward for some help,
Sincerely,
Francis
For me it looks like overheated metal and maybe too hot mould. Also too much borax, I think these big somoth “unfilled” places are where borax was.
hey Francis,
Can you answer these questions so that I can analyse the cause??
  1. What Investment powder do you use & the mixing procedure adopted ??
  2. What is the Burnout cycle used for the above design??
  3. What was the Flask temperature after burnout & during casting??
  4. What was the metal temperature of cast metal??.
  5. How many times have you used this metal ?? ( Is this a fresh metal or recycled metal)??
    If you can reply me to the above questions in detail I will be able to help you solve the problem.
    From the picture you have sent it feels like you have the below mentioned problems:
  6. Investment Powder related mixing issue.
  7. Improper Burnout issue.
  8. Flask Temperature maybe too low.
  9. Metal temperature maybe too high.
  10. Issue of gas porosity due to high temperature.
    Awaiting for your reply
    Prakash V Pai
    INDIA
